RobotStudio - creating system error
Hi, i get an error as shown in screen during creating new solution with station and robot controller. Reinstall doesn't help and also same happens on 64-bit version. Could anyone tell me how can i fix it?
  • Have you tried creating a blank solution, then selecting the robot you want from the library, finally use  'from layout' option under the robot system button?
