World Zone Box setting to turn 45 tilted
Hi .
I would like to know if there is any case you have used world zone box for 45 z-axis tilted from base as Our extraction area is tilted 45 degree.
Is there any way to setting world zone 45 degree tilted and make 45 degree turned box from robot base? I can turn robot base 45 degree tilted but i have to use normal world zone, too.
Thank you for reading.
Hello,ShapeData are defined in World Coordinate System. You can't apply them orientation.You can make a second task managing this.☑️2024 - RobotStudio® User Group0
- 38 AppStudio
