Event error Code to PLC
Hello
I want to send the error code of the event message occured to PLC, Im talking about ERRORID, is it possible? what variables should i use? because ERRNO type ERRNUM couldnt help, im looking for event errors.
Thank you.
Thank you.
Read up on errtype, maybe it will do for you what you are asking.Lee Justice0
Whoops, that is the data type, instruction is: ReadErrData.Lee Justice0
- 38 AppStudio
