Deadman Switch Output?
Vicente
Hi, I have an IRC5 Compact controller, and I was wondering if there is any 24V output signal or any signal at all that tells me if the deadman switch is being pressed or not. Is there any? Is so, which one?
Best Answer
You could make a cross connection of the system outputs 'motors on state' and inverted/not 'Auto on' - this would go high when in manual mode with motors on (the only way for this to happen is the deadman switch is pressed)
Note this would not be a safety rated signal.
5
Okey, kind of a bummer. Thanks for the answer anyway.0
