Calibration Robot with Rapid Program(Automatically)
Hello everyone. I need to calibrate an external axis in the robot program, automatically. I don't want to calibrate physically on the flexpendant so I need to find a way to calibrate with the program. I have looked at Screen Maker but it won't help me. I need to put a signal for physical calibrate on flex pendant but I don't know how to do? Thank you.
Best regards.
  • Is it a rotating external axis?
    Lee Justice
  • Yes, exactly. It will turn always infinity. Because of that encoder won't count how many degrees it has. So I need to calibrate it for example every day or every week.
  • What you need to use is IndReset, read up on it in the manual.
    Lee Justice
  • I know IndReset . But when I used it, it didn't work. It didn't make my external axis's encoder value 0...
  • Not encoder value, value in degrees of rotation should reset to 0.
    Lee Justice
  • I read position value from GetJointData.... \position:= (here)
    and when i used IndReset, this position value is not changing to 0.
    So the value can go infinity some time later i need to make 0 this position value. And i can do this with flexpendant> calibration> fine calibration.
    But i need to find a way to send a signal to flexpendant's calibration menu :)
  • It works for us, here is the code we use:
    PROC stopTableRotation()
    ! stops rotation of turntable and resets revolutions to zero
            ! Turn off speed monitor
            SetDO do07_ZeroMonitorOn, 0;
    ! command turntable speed of 0 deg./sec.
            IndCMove MTT180, 2, 0\Ramp:=10;
            WaitUntil IndSpeed(MTT180,2\ZeroSpeed);
            ! command turntable position of 0 degrees
            IndRMove MTT180, 2\ToRelNum:=0\Fwd, 45\Ramp:=10;
            ! wait for turntable to reach commanded position
            WaitUntil IndInpos(MTT180, 2) = TRUE;
    WaitTime 0.5;
            ! reset turntable position
    IndReset MTT180, 2\RefNum:=0\Short;
    Lee Justice
