Is it possible to copy values from two dimension array's row to one dimension array easily?
                    jeppe
For simplified example, there's two arrays:
array1{3,3}:=[[1,2,3],[4,5,6],[7,8,9]];
array2{3};
Is it possible to copy values from array1, lets say row 2, to array2 easily? Only way to do this which i've found so far is doing it one value at a time:
array2{1}:=array1{2,1};
array2{2}:=array1{2,2};
array2{3}:=array1{2,3};
doing it one by one isn't really an option with my full scale project
Thanks for help!
-Jeppe
            Best Answers
            Here's a basic example:MODULE mArrayLoopExample
 CONST num array1{3,3}:=[[1,2,3],[4,5,6],[7,8,9]];
 PERS num array2{3}:=[0,0,0];
 PROC ArrayLoopExample()
 FOR i FROM 1 TO Dim(array1,2) DO
 array2{i}:=array1{2,i};
 ENDFOR
 ENDMODULE
 5
            Taking the example a little further:MODULE mArrayLoopExample
 PROC ArrayLoopExampleCall()
 ArrayLoopExample array1, array2;
 PROC ArrayLoopExample(num InputArray{*,*}, INOUT num OutputArray{*})
 FOR i FROM 1 TO Dim(InputArray,2) DO
 OutputArray{i}:=InputArray{2,i};
 ENDFOR
 ENDMODULE
 5
            Thanks soup, i'll probably use your second example's idea in my project.
            No problem! Good luck!
            Someone asked privately -- here's a loop within a loop example:MODULE mArrayLoopExample
 CONST num In1{5,3}:=[[1,2,3],[4,5,6],[7,8,9],[10,11,12],[13,14,15]];
 PERS num Out1{3}:=[0,0,0];
 PERS num Out2{3}:=[0,0,0];
 PERS num Out3{3}:=[0,0,0];
 PERS num Out4{3}:=[0,0,0];
 PERS num Out5{3}:=[0,0,0];
 PROC ArrayMain()
 ArrayLoop In1, "Out";
 Stop;
 ArrayZero In1, "Out";
 PROC ArrayLoop(num InputArray{*,*}, string OutputArrayName)
 VAR num tempArray{3};
 FOR j FROM 1 TO Dim(InputArray,1) DO
 GetDataVal OutputArrayName+NumToStr(j,0),tempArray;
 tempArray{i}:=InputArray{j,i};
 ENDFOR
 SetDataVal OutputArrayName+NumToStr(j,0),tempArray;
 ENDFOR
 PROC ArrayZero(num InputArray{*,*}, string OutputArrayName)
 FOR j FROM 1 TO Dim(InputArray,2) DO
 tempArray{j}:=0;
 ENDFOR
 ENDFOR
 ENDMODULE
- 363 IRC5
- 80 OmniCore
- 853 RAPID Programming
- 30 AppStudio
