Any solution to physical control?
I have some transporters that must work together. I make a copy of the pallet with Source and apply physical behavior to that copy. "I turn OFF" the component "PhysicsControl" to be able to move the pallet from one end to the other and "turn it ON" when I want the mechanism to act on the object. For the first mechanism works without problems, but when I want to transfer it to the next, I use a sensor to make the transfer of object (SensedPart), but this last does not recognize the physics that the pallet originally brings and does not allow me to continue interacting and controlling the position by actuating the mechanisms.
Any idea how to solve this? Any help is welcome ...
Best regards!
ChPp.
