Deleted
NicolaB
NicolaB
edited March 2019 in RAPID Programming
Error
Post edited by NicolaB on
  • DenisFR
    DenisFR ✭✭✭
    You should use AliasIO in you case.
      VAR string sVarValue:="8";
    VAR string sVarName:="goTest";
    VAR signalgo goAlias;
    VAR num nValue;
    IF StrToVal(sVarValue, nValue) THEN
    AliasIO sVarName,goAlias;
    SetGO goAlias,nValue;
    ENDIF
    To set input, you can use Cross Connections.
