RAPID not updating changes
Hows it going I'm new to robot studio. I'm having an issue with robot studio not saving work objects I've created in the rapid calibration data module and not synchronizing to vc created programs. Can yall help me with this issue, pls? thanks in advance.
When you say Rapid are you meaning the real robot or the station (graphical environment)?
station0
If the workobject already exists in the VC try deleting it before syncing.
If there are no targets associated with the workobject in the station try adding one (also has to be part of a path to work) then syncing.
yeah it showed up after i created a path and synced it. thanks for the help
- 40 AppStudio
