Any function using UserAuthorizationSystem causes Unknown error (0xC004FFFF) by RW 6.08
Runesmacher
edited April 2019 in Developer Tools
We recently updated our Robots from RW 6.05.00.04 to RW 6.08.01.00
We use a program to change some config settings in the robot more easily.
Since the upgrade to RW 6.08 i am getting the following error while executing anything with the UserAuthorizationSystem. I tested multiple things (even getCurrentGrants and GetGrantTypes) All are giving me the following error.
The controller is already logged on as Default User and i am trying to check if this user has the grants for writing configurations. (To see if i need to show a seperate login screen for ex. Administrator)
Small code snipet (2nd line gives error)
UserAuthorizationSystem uas = controller.AuthenticationSystem;
if (!uas.CheckDemandGrant(Grant.WriteConfiguration))
Error:
ABB.Robotics.GenericControllerException
  HResult=0xC004FFFF
  Message=C004FFFF : Unknown error (0xC004FFFF)
剅佒㩒爠桤损湯牴汯敬⹲灣孰㐵㈴㩝漠杲损摯㩥ⴠ㔷‷敮彷潣敤›砰っ㐰晦晦※
Url:  Cmd:READ  Prop:UASConfig -Part Grants  Args:  Elapsed:17  CurrentCmds:0
History:
-00:00:16.1914043 [4] status:294912 data:-noelts,all,mark,cc     6,1,         0, ...
-00:00:16.1914043 [3] status:294912 data:0
-00:00:16.1854204 [5] SendCommand url: cmd:Set prop:LogoffUser arg:-Uid 2
-00:00:16.1634799 [5] status:294912 data:
-00:00:16.1594907 [6] SendCommand url: cmd:Set prop:LogonUser arg:<hidden> -locale Remote -app "" -loc "PC_NAME" -alias "PC_USER"
-00:00:16.1325634 [6] status:294912 data:-Uid 3
-00:00:16.1325634 [7] SendCommand url: cmd:Get prop:IsOptionPresent arg:-Option PCIN
-00:00:16.1126168 [7] status:294912 data:-OptionPresent 1
-00:00:16.1126168 [8] SendCommand url:/CONFIG/MMC/IOVIEW_BLOCK/IOViewBlockIfMotorsOff/enabled cmd:Get prop:Value arg:
-00:00:16.0926705 [9] SendCommand url: cmd:Set prop:LogoffUser arg:-Uid 3
-00:00:16.0926705 [8] status:294912 data:0
-00:00:16.0717267 [9] status:294912 data:
-00:00:16.0707312 [10] SendCommand url: cmd:Set prop:LogonUser arg:<hidden> -locale Remote -app "" -loc "PC_NAME" -alias "PC_USER"
-00:00:16.0467953 [10] status:294912 data:-Uid 6
-00:00:16.0467953 [11] SendCommand url: cmd:Get prop:IsOptionPresent arg:-Option PCIN
-00:00:16.0268482 [11] status:294912 data:-OptionPresent 1
-00:00:16.0268482 [12] SendCommand url:/CONFIG/MMC/IOVIEW_BLOCK/IOViewBlockIfMotorsOff/enabled cmd:Get prop:Value arg:
-00:00:15.9989231 [12] status:294912 data:0
-00:00:00.0189629 [13] SendCommand url: cmd:READ prop:UASConfig -Part Grants arg:
-00:00:00.0010109 [13] status:-1073414145 data:剅佒㩒爠桤损湯牴汯敬⹲灣孰㐵㈴㩝漠杲损摯㩥ⴠ㔷‷敮彷潣敤›砰っ㐰晦晦※
  Source=ABB.Robotics.Controllers.PC
  StackTrace:
   at Adapters.Uas.GetUasConfig()
   at Internal.Uas.LoadConfiguration()
   at Internal.Uas.LoadGrants()
   at Internal.Uas.CheckGrant(String grant)
   at ABB.Robotics.Controllers.UserAuthorizationSystem.CheckDemandGrant(String grant, String& value)
   at ABB.Robotics.Controllers.UserAuthorizationSystem.CheckDemandGrant(Grant grant)
   at RobotInstaller.FormRobotInstaller.buttonInstallRobotConfig_Click(Object sender, EventArgs e) in C:\Git\Robotics\tooling\RobotInstaller\RobotInstaller\FormRobotInstaller.cs:line 83
   at System.Windows.Forms.Control.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
   at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
   at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
   at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
   at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
   at System.Windows.Forms.Application.Run(Form mainForm)
   at RobotInstaller.Program.Main() in C:\Git\Robotics\tooling\RobotInstaller\RobotInstaller\Program.cs:line 16
Inner Exception 1:
RobApiException: C004FFFF : Unknown error (0xC004FFFF)
History:
Does anyone has any idea why this can be? and how i can get this resolved?
The exact same program works on the RW 6.05 version.
Thanks in advance for any info.
