Unable to use Backup and pack&Go
Hardikez
i am unable to do backup and use pack&Go
every time i use this f**ktion a message appears telling me that VC has encountert a problem an need to be close.
the controller works fine both in RS and AWPP
i have just upgradet to 5.08 for both RS and AWPP
i had same problem with 5.07
HELP is needet
Kent Zibrandtsen
Dept manager robot welding
Kez@hardi-international.com
SORRY FOR THE MISTAKE IN "FUNCKTION":)Kent Zibrandtsen
Kez@hardi-international.com0 -
Is this when you run the Pack & Go wizard, or when you open the station on a different computer?
Johannes Weiman
Software Engineer
ABB Robotics0 -
Hei kent.
I have tried it and it works for me. I use the same options as you.
Best regards klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
It chrashes when I use the funktion on my computerKent Zibrandtsen
It happens both if i use pack and go, but also if i try to backup with flexpendant. every time i try the controller crashes.Kent Zibrandtsen
That sounds strange. Which RobotWare version is the controller using?
Johannes Weiman
Software Engineer
ABB Robotics0 -
im am using Robotware version 5.07.1030.01
Kent Zibrandtsen
No matter which options i chose in the pack and go wizard, i always seem to get the systems and backups included the zip file. Has anyone else found this?
Regards
Craig Pentecost
Hi Craig,
Systems are always included, there is no option to disable that.
If you uncheck backups new backups shouldn't be created, however existing backups in the system (the BACKUP subfolder) will still be included.
regards,
Johannes
Johannes Weiman
Software Engineer
ABB Robotics0
- 40 AppStudio
