Invalid CPCRC - During CIP safety scanner / external device configuration
pandreuw
I hope you can help me to find the solution to this issue:
My robot information:
On Lan 2 I have an IO module and the camera, I Isolated LAN3.
On LAN 3 I connected a sick safety scanner MICS3-ABAZ55IZ1.
The scanner is already configured, I set an IP Address of 192.168.1.11 and generated the SNN and SCID.
I configured the robot following the information on "Application manual EtherNet/IP Scanner/Adapter".
Robot IP Address 192.168.1.10 on Lan 3.
I set the communication first.
Then the "Industrial Network"
Then the "Ethernet/IP IO connection"
Then the "Ethernet/IP Device".
Then I went into the SafeMove vizualizer, configured some zones, tools. After this was done, I entered the information on the safemove "IO Configuration". Entered the SNN and the SCID.
After fixing some errors I reach this point in which I cannot go further, I do not find information about this error:
What is CPCRC and how do I fix this error?
I do not have communication with the scanner.
Thanks in advance for reading and help me out on this issue.
BR
Gerardo
- RW 6.08.01
- irb2600
- 841-1 Ethermet/ip Scanner/Adapter
- 1341-1/1520-1 Integrated vision interface
- 1125-2 SafeMove Pro
- 997-4 CIP safety Scanner and Adapter
- plus other options.
BR
Gerardo
just gelalo
