SetAO with decimal place
I'm trying to set an virtual analogue output using values from an array, these values have one decimal place but when I try to set the signal in Rapid I don't get the decimal, here's what I'm doing;
So I'm trying to set the signal ACNV_Spdmm using the value from nCur_Spdmm which currently is 15.9 but the output gets set to just 15.  Other standard analogue signals are working with decimals so I don't know what I'm missing...
Any ideas?
  • Neily03
    Neily03 ✭✭✭
    As a test I've tried the following:
    And still only outputs '15' without the decimal.......
  • Neily03
    Neily03 ✭✭✭
    Fixed it by removing the assigned unit and leaving it blank.
  • DenisFR
    DenisFR ✭✭✭
    signalxx data are integers.
    The easier way to transmit real is to multiply your values ex: 15.9*10.
