C# program- g code with ABB robot?
Hello
I'm trying to develop a school proyect using a 120-503244 ABB robot and a IRC5 controller
i have to do a 3D printer with the robotic arm
i want to do a program in C# preferently, in which i can  import a g- code and sent it to the robot, or some function to send a rapid file to the robot
and some way at the same time to connect that C# program with pronterface software to be able to print
Now i have a C# program in which i can detected the controller and select the controller and start comunication with rapid, but the rapid program is on the flex pedant
this is the code:
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using ABB.Robotics;
using ABB.Robotics.Controllers;
using ABB.Robotics.Controllers.Discovery;
using ABB.Robotics.Controllers.RapidDomain;
using System.Threading;
namespace PCSDK_Csharp_BasicScanApp_560
    public partial class Form1 : Form
        private NetworkScanner scanner = new NetworkScanner();
        private Controller controller = null;
        public Form1()
            InitializeComponent();
        private void Form1_Load(object sender, EventArgs e)
        private void btnScan_Click(object sender, EventArgs e)
            DisableControllerFunctionality();
            listView1.Items.Clear();
            this.scanner.Scan();
            ControllerInfoCollection controllers = scanner.Controllers;
            ListViewItem item = null;
            foreach (ControllerInfo controllerInfo in controllers)
                item = new ListViewItem(controllerInfo.IPAddress.ToString());
                item.SubItems.Add(controllerInfo.Availability.ToString());
                item.SubItems.Add(controllerInfo.IsVirtual.ToString());
                item.SubItems.Add(controllerInfo.SystemName);
                item.SubItems.Add(controllerInfo.Version.ToString());
                item.SubItems.Add(controllerInfo.ControllerName);
                this.listView1.Items.Add(item);
                item.Tag = controllerInfo;
        private void EnableControllerFunctionality()
            // put all the enable and disable functionality in the same place so that it is easy to reuse
            label1.Visible = false;
            listView1.Enabled = false;
            gbxControllerSelected.Visible = true;
        private void DisableControllerFunctionality()
            label1.Visible = true;
            listView1.Enabled = true;
            gbxControllerSelected.Visible = false;
            if (this.controller != null) //if selecting a new controller
                this.controller.Logoff();
                this.controller.Dispose();
                this.controller = null;
        private void StartProduction()
            try
                if (controller.OperatingMode == ControllerOperatingMode.Auto)
                    using (Mastership m = Mastership.Request(controller.Rapid))
                        this.controller.Rapid.Start();
                else
                    MessageBox.Show("Automatic mode is required to start execution from a remote client.");
            catch (System.InvalidOperationException ex)
                MessageBox.Show("Mastership is held by another client. " + ex.Message);
            catch (System.Exception ex)
                MessageBox.Show("Unexpected error occurred: " + ex.Message);
        private void listView1_SelectedIndexChanged(object sender, EventArgs e)
        private void listView1_DoubleClick_1(object sender, EventArgs e)
            ListViewItem item = this.listView1.SelectedItems[0]; if (item.Tag != null)
                ControllerInfo controllerInfo = (ControllerInfo)item.Tag;
                if (controllerInfo.Availability == Availability.Available)
                    if (controllerInfo.IsVirtual)
                        this.controller = ControllerFactory.CreateFrom(controllerInfo);
                        this.controller.Logon(UserInfo.DefaultUser);
                        EnableControllerFunctionality();
                    else //real controller
                        if (MessageBox.Show("This is NOT a virtual controller, do you really want to connect to that?", "Warning", MessageBoxButtons.YesNo, MessageBoxIcon.Warning) == System.Windows.Forms.DialogResult.Yes)
                else
                    MessageBox.Show("Selected controller not available.");
        private void btnProduction_Click_1(object sender, EventArgs e)
            if (controller.IsVirtual)
                StartProduction();
            else
                if (MessageBox.Show("Do you want to start production for the selected controller?", "Warning", MessageBoxButtons.YesNo, MessageBoxIcon.Warning) == System.Windows.Forms.DialogResult.Yes)
                    StartProduction();
