Dialog box on a PC instead of the FlexPendant. C#
Can someone share an example of a PC SDK dialog box launched on a PC instead of the FlexPendant when Rapid UI and TP instructions are executed? When an operator will be able to give the feedback required by the Rapid program form a PC instead of using the FlexPendant.
Any example will be appreciated. Something...
Thank you
