Failed to install RobotStudio 2019
in UpFeed
Hello!
I just tried to install RobotStudio 2019. It failed with the following message:
It says "Database: Transformation: One row is missing and could not be updated. Table: Feature."
After clicking OK the Installation is aborted. No changes were made.
Are there known issues upgrading from 6.08. ?
The exact old Version is 6.08.8307.1040 on a Win10 Enterprise Version 1703, Build 15063.1839.
The folders for User documents, solutions, screenshots and screen records are changed from standard.
No further changes.
Regards
Michael Kobbeloer
There was a problem with installing in non-English language but that should be fixed now.
Try downloading again or select English language in the installer.
Johannes Weiman
Software Engineer
OK, I will try it again. This will take a few days.I have to download at home because our internet connection here at work is way too slow for the 2.4 GB...0
As I said, you can also select English language in the installer.
Johannes Weiman
Software Engineer
Yes, you are right! It works well with the English language.Thanks for advice.0
- 364 IRC5
- 83 OmniCore
- 37 AppStudio
