Trouble with RobotStudio 2019.1 32-bit
SamR
Dear support team,
after upgrading to RobotStudio 7.0 (2019.1), we were not
able to open/create projects with the 32-bit version. Also, the interface looks fairly
different compared to the 64-bit version. We checked if there is an issue with the license, but the installed licenses
are identical.
Any ideas on what went wrong on our systems?
A screenshot of a comparison between the interfaces and licenses is attached.
Thank you in advance.
Kind regards,
Markus
This is by design. Offline programming and modeling is deprecated in the 32-bit version; it only supports online operation.
Johannes Weiman
Software Engineer
RobotStudio Team, ABB Robotics1 -
How do we import geometry?The only way I could import STEP was via 32bit.0
- 858 RAPID Programming
