How to change mode from MANUAL to AUTO with a Keyless controller?
Luxrobotic
Hi everybody,
I'm currently installing an IRB2600 Keyless robot, and I'm wondering if it's possible to make the change of mode frome MANUAL to AUTO by setting an Input?
Thanks
Regards
http://www.luxrobotic.com
Cornet Raymond
Manager
+352 621 354 570
raymond.cornet@luxrobotic.com
HP ZBook Fury 16 G11
Hi everybody,These options are installed in the system :
I tried with configuring this SysInput :-Signal "diPN_Bit_6_AckAutoMode" -Action "AckAutoMode" -Arg7 "T_ROB1"But nothing happens when activated.any idea?
RegardsCornet RaymondManager+352 621 354 570raymond.cornet@luxrobotic.com
http://www.luxrobotic.comHP ZBook Fury 16 G110 -
The only controllers that I have seen without keys still had a switch, just no key.Lee Justice0
Hi,finally we found the solution, by using the following SysInput :-Signal "diPN_Bit_5_AckAutoMode" -Action "AckAutoMode" -Arg7 "T_ROB1"
-Signal "diPN_Bit_7_RemoteOpModeEnable" -Action "RemoteOpModeEnable"\
-Arg7 "T_ROB1"
-Signal "diPN_Bit_6_OpModeReqAuto" -Action "OpModeReqAuto" -Arg7 "T_ROB1"
-Signal "diPN_Bit_8_OpModeReqManual" -Action "OpModeReqManual"\
-Arg7 "T_ROB1"But now, I'm facing the problem with the Emergency stop reset.I configured this SysInput :-Signal "diPN_Bit_9_ResetEmergencyStop" -Action "ResetEstop"
But I get this error message when I set it :20148: Confirm rejected
Description
Emergency Stop reset confirm, via System IO, was rejected.Any idea?Thanks
Ensure that the runchain has been reset first.Lee Justice0
HI,now everithing's ok. We were just trying to reset the ES and set the MotorOn while the robot was in Manual mode.It needs to be in Auto mode !Thanks anyway.RegardsCornet RaymondManager+352 621 354 570raymond.cornet@luxrobotic.com
I hope you have high safety standards. An accidental switch to auto could harm someone.
- 858 RAPID Programming
