change Aprox. max in analog output
<div>hello! i need to change the Approx. max on my analog output AU_TCP , i need ich to be 1E 04 like the other one on the pic</div>someone to help?<b><i></i></b><i></i>
Hello,It's defined in your EIO.cfg file or in Configuration - I/O System - Signal.Check Maximum Logical Value of your AO_TCP signal.☑️2024 - RobotStudio® User Group0
- 858 RAPID Programming
