function argument is not a is not a constant expression
kschmid
This must be a pretty trivial error, can I pass arguments as constant?
Or do I even have to? radius should be a copy here ?
CONST num circum := l_PI * 2. * radius;
gets me
System1/RAPID/T_ROB1/Module1(317,41): Data declaration error(20): Expression radius is not a constant expression. 5/08/2019 3:57:31 PM General
Also getting similar result with FUNC.
num radius is not a copy?
it works with everything in 1 line but that's silly
PROC get_pitch(num turnSpacing, num radius, INOUT num slope_angle)
slope_angle := toDegree(ATan(turnSpacing / l_PI * 2. * radius));
Post edited by kschmid on
It needs a constant, because you declare and initialize the value at the same line.
</code>CONST num circum := l_PI * 2. * radius;<br> ^ ^<br> | |<br></pre><br></div><div>You can fix this by doing this for example:</div><div><br></div><div><pre class="CodeBlock"><code>PROC get_pitch(num turnSpacing, num radius, INOUT num slope_angle)<br> VAR num circum := l_PI;<br> circum := l_PI * 2. * radius;<br>ENDPROC
or<code>VAR num circum;<br>PROC get_pitch(num turnSpacing, num radius, INOUT num slope_angle)
2 -
let me try, i think CONST didnt do it.Ah, right i need to declare separately. First time i meet a language with that requirement but thanks for your help0
Hi Eric, Thanks for your answer, which also solved my problem.
I am wondering, why seperate the declaration and assignment expression could solve the problem. Is there anything to do the way Robotstudo allocates it's memory?
Appreciated!0
- 37 AppStudio
