Safe move configuration error
Jamiem
I’m currently trying
to configure the safe move properties on our IRC5 6700 robots. I’m currently
experiencing issues when I attempt to download a safety configuration file into
one particular controller. I’ve setup appropriate user access
accounts and have no luck when downloading. I originally thought it was
something in my configuration that that controller didn’t like but I get the
same error code when I download a blank configuration with just a single tool.
I have followed the same steps I used when loading into other controllers
successfully and still no luck. Attached you will find the error code I receive
when I download both blank files and configured files. I have also tried resetting the safety controller back to
factory default settings and get the same error. Do you see anything that would
cause this error or do you have any ideas on something to try? Does this seem
like a hardware or software issue?
C004AB14 : Operation for the safety controller failed.ERROR: rdh_controller.cpp[9193]: org_code: -7722 new_code: 0xc004ab14; Url: Cmd:SET Prop:ScorchLoadSupervConfig Args:-File "(TEMP$)/197a868c/tmp47C1.tmp" Elapsed:104 CurrentCmds:0
- 40 AppStudio
