Creating Robtargets with Locked axis
I've created a station from a mediapool that utilizes a lock axis in a genkin robot carrier.
I've also used the scripting tool to generate a library that has a joint with limits: 0 to 0.
The controller appears to function correctly. But, I get the following error when creating a robtarget in Robotstudio:
RobotStudio .NET exception dump
Base exception:
Index was outside the bounds of the array.
at ABB.Robotics.RobotStudio.Stations.RsTask.GetExternalAxisJoin tTypes()
at ABB.Robotics.RobotStudio.Stations.RsTask.GetExternalAxisJoin tValues()
at ABBInternal.ElementCommands.ElementCommandServices.GetExtern alAxisValues(RsTask task)
at ABBInternal.ElementCommands.TeachTargetAndMoveInstructionHel per.CreateAndAddNewTargetOrMoveInstruction(Boolean justTarget, Station stn, RsPathProcedure path, RsWorkObject workObject, RsToolData tool)
at ABBInternal.ElementCommands.TeachTargetAndMoveInstructionHel per.TeachTargetOrMoveInstruction(Boolean justTarget)
at ABBInternal.ElementCommands.TeachTargetCommandHandler.TeachT argetCommandHandler_ExecuteCommand(Object sender, ExecuteCommandEventArgs e)
at ABB.Robotics.RobotStudio.Environment.CommandBarButton.RaiseE xecuteCommand()
Any ideas? I thought defining the library using the script tool to acheive a 0 to 0 limit would correct this problem. Are the library axes mapping correctly to the VC axes? Any help would be greatly appreciated.
DanS2007-3-13 3:47:30Comments
Attached is the script file used to generate the mechanism.
If you mail me a backup of the system, the mediapool for the gantry and the sat-files to the mechanism, I can take a look at it.
ABB Robotics0
- 399 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 338 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
- 107 Collaborative Robots
