RobotStudio Synchronize to Station
Options
Smith666
Is there any way to synchronize to station the robtargets that are declared in the array?
From the Robot Studio Operator's Manual:
Limitations• Robtargets that are local to a procedure are not supported by Synchronizeto Station. Only robtargets that are local to a module are supported.• RobotStudio does not fully support instructions using Offs or RelToolfunctions. These are synchronized and will appear in the element browser,but commands such as View Tool at Target and Locate Target will not work.Targets used in the instructions will not be visible in graphics. However,instructions can be programmed and edited using the RAPID Editor and canbe simulated using the virtual controller.• RobotStudio does not support RAPID programs containing arrays of tooldata,robtargets and workobjects. These programs will not be synchronized to thestation.• Workobjects and tooldata that are shared between several tasks must bespecified in RAPID with its full value for each task when programming offlinewith RobotStudio. This will trigger a warning Initial value for PERS not updatedin the controller event log. You may ignore this warning. However, ensurethat the RAPID variable definitions are the same in all tasks, otherwise youmay get unexpected behavior.1 -
Did you create some code automatically split up your array & create separate robtargets?0
- 400 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 348 IRC5
- 74 OmniCore
- 845 RAPID Programming
- 21 AppStudio
- 109 Collaborative Robots
