Application problem with Mastership release
EugeneB
I'm testing one of the functions in c# application. Something happened
and my Robot Studio virtual station is stuck with - Remote Write Access - from
one of my testing. Not sure what exactly happened but I glad it did. Now when I
trying to run my application is throwing me an exception - Requested
resource is held by someone else. Now I need to come up with the solution if this happens
in production. How can I check if is Mastership is held by someone else and if
yes then dispose or check if it's my mastership and if it's mine then continue?
This is an example of my code where is throwing an exception:
try
if (controller.OperatingMode == ControllerOperatingMode.Auto)
tasks = controller.Rapid.GetTasks();
using (Mastership m = Mastership.Request(controller.Rapid)) // on this line is throwing an exception
if (m.IsMaster != true)
tasks[0].LoadModuleFromFile(filePath, RapidLoadMode.Replace);
//controller.IOSystem.GetSignal($"{startSignal}");
// set digital signal
//Signal sig = controller.IOSystem.GetSignal(startSignal);
//digitalSig = (DigitalSignal)sig;
//Perform operation
tasks[0].Start();
Will appreciate any help.
Thank you,
Thank you,
