image on teach pendant
I want an image to be displayed of the part that is going to be welded on teach pendant or flex pendant. where would I have to save the file in robotstudio to view it during simulation and in our flexpendant. What file type has to be used.
PROC HS_L_VI()
UIMsgBox\Header:="VERIFY",MsgLine1:="DIRECTON : "+ValToStr(HS_L_DISPLAY)\MsgLine2:="QTY : "+ValToStr(HS_L_N)\Buttons:=btnYesNoCancel\Icon:=iconWarning\Image:=HS_L_IMAGE.pdf\Result:=btnVERIFY;
If btnVERIFY=7 THEN
UIMsgbox\Header:="RETRY",MSgLine1:="Renter Values"\Buttons:=btnOK\Icon:=iconInfo;
HS_L_ID;
ELSEIF btnVERIFY=5 THEN
UIMsgBox\Header:="CANCELED",MsgLine1:="Routine Canceled"\Buttons:=btnOK\Icon:=iconError;
main;
ENDIF
UIlIstView uses ListItem data to show a 28 x 28 pixel image on the pendant. Would that satisfy your needs? Also, do you have production manager option? I think that allow for images if you have it and configure it correctly. .jpg, maybe .png files save in HOME directory.Lee Justice0
Hello RickyTre91,
I think you need the option "FlexPendant Interface" to be able to use images which are located in the home directory.
/BR
Micky0 -
I would like to select/run the program and have an image be displayed of the part that program is intended to weld.
Search the RAPID manual for "300 pixels" and read-up on the image options for message boxes.
- 38 AppStudio
