Backup path is not changed even if remotePath is
e_tip
Hi, i'm developing an utility for my company to manage the robots we have,
i'm having problems with backup code :
But even if i've specified /hd0a/BACKUP as remoteDirectory my backups are always made inside HOME...
Any suggestions ?
Tia
var destinationPath = "2019_10_10";
if (!this.isConnected)
this.Connect();
Console.WriteLine(_ctrl.FileSystem.RemoteDirectory);
_ctrl.FileSystem.RemoteDirectory = "/hd0a/BACKUP";
Console.WriteLine(_ctrl.FileSystem.RemoteDirectory); <-- used this only for be sure that RemoteDirectory is changed
if (!Directory.Exists(Path.Combine(localPath, DateTime.Now.ToString("dd-MM-yyyy"), Info.ControllerName)))
Directory.CreateDirectory(Path.Combine(localPath, DateTime.Now.ToString("dd-MM-yyyy"), Info.ControllerName));
_ctrl.BackupCompleted += (object e, BackupEventArgs evt) =>
Console.WriteLine("Backup over");
_ctrl.Backup(destinationPath);But even if i've specified /hd0a/BACKUP as remoteDirectory my backups are always made inside HOME...
Any suggestions ?
Tia
Hello Tia,
please try the following:_ctrl.FileSystem.RemoteDirectory = _ctrl.GetEnvironmentVariable("Backup");or_ctrl.FileSystem.RemoteDirectory = "(Backup)$";
or if you want to address the path on the controller you have to add "ctrl:":_ctrl.FileSystem.RemoteDirectory = "ctrl:/hd0a/Backup";
The two upper versions also work on the virtual controller
Best regards
Micky0
