PC SDK causing application freeze in a .Net 4.7.2 x64 multithreaded application on Windows 10
labu
We are developping our application for robots interfacing and vision since over 10 years and are recently facing issues with the PC SDK.
Quite frequently, when accessing controllers or rapid datae, we end in a main thread (UI) freeze.
One typical situation is as shown above in a call stack capture while locked on the Monitor.Wait. (in this case setting a userdefined Rapiddata)
We are running a 64 bits App on Windows 10 .Net FW 4.7.2.
ABB.Robotics.Controllers.PC, Version=6.6.7624.115
If any of you has got such trouble, help would be warmly appreciated as we struggle to come over the issue.
Many Thanks
Many Thanks
Have you tried the latest version of PC SDK? 6.6 is quite old.Johannes Weiman
Software Engineer
I have same problem now.
PC SDK version : 2019.5
Specially, when function "Controller.Dispose()" is called,
application is freezed.
Please help?0
