IRC5 Multimove Error 50432 Identical base frame
I am not able to find any help to resolve the error 50432 identical bas frame. The mechanical units ROB_1 and ROB_2 have identical base frames
New to multimove.
  • Can you post a screenshot of robot studio? How did you set them up? With multiteach?
  • One of the robots is physically in a different place to the other, so the baseframe of the second robot must reflect this difference in position.
    The MultiMove manual has a chapter called Calibration which explains how to calibrate the second robots base frame.
    Thanks works perfect as given in manual.
