timeout problem
ryan
I have a problem about creating a new sytem from backup. When I try to create from backup with true RW version timeout occurs. "Starting" displays on screen longer than normal, then "Error - timed out" displays and a dialog box says "There was a problem starting the virtual controller".
This is from logfile:
2007-03-16 18:32:22 : CLgVCHelper::Shutdown(): Timeout! File:.LgVCHelperImpl.cpp:297
I do the same things with another computer (the same backup and RW version) and RS creates the system with no error.
Can anyone tell me where the problem is?
Thanks
Onur Altunta_ / Turkey
ryan2007-3-17 14:49:40Onur Altunta? / T?rkiye
I would guess that this is a DualCore problem. There are a couple of threads in this forum about it and here is one http://forums.robotstudio.com/forum_posts.asp?T ID=1183&PN=1Per Svensson
Consat Engineering0 -
I disabled Dual Core and problem solved. Thank you so much for your help.
Onur Altuntas / Turkey
Onur Altunta? / T?rkiye0
- 363 IRC5
- 79 OmniCore
- 853 RAPID Programming
- 30 AppStudio
