Error handler during EGM
csmith
I'm trying to recover from any motion errors while my robot is controlled through EGM.
My current Rapid code:
Whenever I run into an Error during EGM, my error handler won't execute.
How can I make this work so I can recover without manually jogging the robot back to a valid position?
Thank you
TEST egm_action
CASE EGM_POSE:
printInfoMessage 1, CONTEXT_EGM, "Starting pose mode";
EGMRunPose egm_id,
EGM_STOP_HOLD,
\X \Y \Z \Rx \Ry \Rz
\CondTime:=20
\RampInTime:=0.1
\PosCorrGain:=1;
DEFAULT:
ENDTEST
EGMReset egm_id;
ERROR
IF ERRNO=ERR_ROBLIMIT THEN
TPWrite "Joint out of range error";
MoveAbsJ homepos,v100,fine,tool0;
ENDIFWhenever I run into an Error during EGM, my error handler won't execute.
Thank you
Check out the system input Interrupt. If you have an error, your system output for error can tell the PLC that there is a problem. Then the PLC can give you that system input. From what I understand, it will act on that without the program running.Lee Justice0
