CTM and Robotstudio Connection
Arun
Hi all, Thank you everyone at first.
I'm new to ABB Robot programming as well as conveyor tracking applications. In my intern's place, I have to work with CTM-01(conveyor tracking module) and IRB 360. Following the manual of CTM, I'm trying to connect robotstudio to the CTM. The IRC5 controller is not connected to robotstudio for the moment(Since the manual explained so). I'm connecting CTM's LAN Port to Robotstudio with the IP address 192.168.126.246 set in my PC. When I open robotstudio and go to conveyor tracking and click on add conveyor, it shows nothing. What could be the possible problem? Without connecting it and setting up a network I'm not able to progress further. Can someone give me some possible troubleshooting to work further.
1
I too have a same problem .can someone give me a possible solution for this issue.....?1
- 40 AppStudio
