Add ethernet/IP option / Connect IRC5 to PLC
Hi everyone
Before I start, I just wanted to let you know that I'm not 100% familiar with the RobotStudio environment and that I'm still new in that domain (Sorry in advance if my problem seems silly).
So I have an IRC5 controller with the DeviceNet Master/Slave option, but I also need to set up a connection between my controller and a PLC (with Sysmac Studio).
In the Configuration - I/O system tab I can see in the industrial network section that I have the DeviceNet but I'm pretty sure I also need  the Ethernet/IP anybus option.
So my questions are:
-Do I really need this option for my application?
-If yes, do I need a license key like, for instance, the multitasking option?
Thank you
  • Look in the backinfo folder for the backinfo.txt file, it will list your options.  If you don't have ethernet/IP option then you will need to buy it and they should give you a new keystring.
    Lee Justice
