Rotation of the Gripper or Work object by an angle
VEDH
Hello All,
I have an Application where in I have the necessity to rotate the Gripper according to the placement of the object.The camera will provide me with the angle which i can pick the piece(object of interest) and now i need to change the orientation of the gripper so that i picks the piece comfortably.
could you kindly suggest any available function in Robot Studio or provide a syntax that fulfills the objective
I am using a IRB360 Flex picker here.
many thanks in advance.
VEDH
I would use the RelTool function, use the Rz data coming from the camera. Please make sure that you have a good TCP.Lee Justice1
