Move indipentently one external axis
Hello i've a robot that has 2 external axis. The problem is the cleaning guys in the night always move "manually" one of the external axis.
Since this robot has more than 1 homeposition i would like to have reset the position of the Axis 7 and 8 wherever the robot is.
For now i wrote this small codes but it works only for the axis 1-6. it give error with 7 and 8.
    PROC Init()
        joint :=CJointT();
        joint.robax.rax_8:=-1.30686;
Thanks.
  • How do you use those axes?  Independent mode, coordinated or a mix of both?
    Lee Justice
  • Elchico11
    Elchico11
    edited February 2020
    Coordinated i think (i'm not sure how can i check it)
  • SomeTekk
    SomeTekk
    Look at a jointtarget in Program Data. External axes are NOT declared ... rax#
    It is more likely the instruction you are looking for is:
    joint.extax.eax_a (1st logical external axis - usually) :=3.14159;
    joint.extax.eax_b (2nd logical external axis - usually) :=-1.30686;
