Mastership.Request(iMastershipResource) is obsolete
In the latest PC SDK, I have a warning that "Mastership.Request(iMastershipResource)" is obsolete and should be replaced with "Request(iMastershipResourceController)".
My existing code is
public static Controller rpdController
Thanks
David
My existing code is
using (Mastership m = Mastership.Request(rpdController.Rapid))
rpdTask.Start();
I'm unsure of how to replace this code with the new version and an internet search comes-up with nothing (so far
Thanks
David
Post edited by Nils Olofsson on
Hello,I don't have last PS SDK to test with it, but in its PC_SDK_Reference_Documentation.chmABB.Robotics.Controllers. Controlleris:
public sealed class Controller : SDKBase, IController, IMastershipResourceController, IMastershipResourceCan you check it in VisualStudio?
Thanks, yes I can view it in VS Object Browser but am stuck with the code changes I need to make.
Hello,Does this works?using (Mastership m = Mastership.Request((iMastershipResourceController)rpdController.Rapid))
Hi again, I tried this but it didn't work.
Thanks
David0 -
please try the following:using (Mastership m = Mastership.Request(rpdController))
1 -
Hi Micky
Thank you very much, that worked.
I only just revisited this issue since it first arose last year.
Regards
David0 -
Just moved the thread into Developer Tools section so it's easier to find if someone has similar problem
—Nils OlofssonPC Software Support Engineer0
