Error when creating a backup of my virtual machine and trying to restore it.
Jannik
I've created a Robotware Addin with custom configuration files to create a profinet connection. This works just fine so far, but if I want to create a backup of that machine and restore it later on, it raises this error:
80001: Invalid IO size on device
This doesn't happen if I load the configuration files manually.
The EIO file I installed with the addin looks like this:
The IO device 'pn_internal_device' has input/output size larger than 0. This is not allowed if IO device slots are configured on the device.
EIO:CFG_1.0::
# Network Settings for PROFINET and Signal definition
PROFINET_INTERNAL_DEVICE:
-Name "PN_Internal_Device" -OutputSize 0 -InputSize 0
-Name "DI_32_bytes" -OutputSize 0 -InputSize 32\
-HostDevice "PN_Internal_Device" -SlotIndex 2 -ModuleID 4
-Name "DO_32_bytes" -OutputSize 32 -InputSize 0\
-HostDevice "PN_Internal_Device" -SlotIndex 1 -ModuleID 3
Does anyone know why this happens?0
