Move Along Path: Command failed. Check the controller status.
EricH
EricH
edited March 2020 in UpFeed
I got this error and can't use the function Move Along Path (with the controller that is used from the station) anymore. Tried to fix that problem by resetting the virtual controller to factory settings with no success. Also a restart of Robotstudio showed no success.
I can fix this by deleting the whole controller and setup a new one, but thats a tedious workaround.
