Multithread in RobotStudio
I am a student in Automation Engineering. I have started using RobotStudio one month ago and I am doing my thesis project with this sw,
In my project I would need to use concurrent threads but I did not find a lot of discussions / guides that explain in details how to do, maybe can  someone suggest me a guide where it is explained?
Thank you!
  • This is called Multitasking  - you need to add the option to your virtual controller (your real controller will need to have the option as well if you plan to down load the code to it later).
  • dragolollo
    edited March 2020
    Thank you! I knew about that tool but I was not able to use it, now I succeed in it.
