ScreenMaker PP_Main / Load / Save
Sylvain
in ScreenMaker
Hi all,
Currently I work on a new HMI and I'm face off 3 problematics.
* PP to Main button.
* Load program button.
* Save program button.
On the pictures bellow you can see the buttons and show you how it works.
When you clic on "Prog_Load" or "Prog_Save", a window with programs file is open. You can directely select the right program to work.
This HMI was developped with VB code by an external integrator. I can't have the source code and I don't have the software to do it.
Is it possible to do this with ScreenMaker please ?
Thank you for your help.
Hi, anyone can help me please ?0
I have seen it done with screen maker - but the list of modules was stored in an array and displayed in a drop down box.
The array was updated by running a RAPID procedure that read through the directory that the modules were stored in, saving each module name into the array.0
- 400 UpFeed
- 20 Tutorials
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 350 IRC5
- 74 OmniCore
- 848 RAPID Programming
- 21 AppStudio
- 109 Collaborative Robots
