Customized tool using external axis
Hiya, new member, M.Sc student having a great interest for simulation equipments.
So, I am trying to figure out a way to create a tool (spotwelding gun) and to use an external axis for the control system to make the joints move. As I try to create a system with my created tool I just get the message seen in the picture below.
My guess is that I messed something up when creating the tool itself. But after a little searching on the forums here I'm thinking of 2 other main reasons:
1. I need to get the Add-in "External Axes Wizard".
2. It doesn't work like this at all, and I need to approach the problem differently.
Any ideas?
Any ideas?
I am no expert in this area - but yes I think you need to use the external axis wizard.
What he said ^^
Thanks for the feedback!0
Just to give an update, the external axis wizard solved the problems, the weld gun is now controllable by an external axis!0
