3D Printing PowerPac
Hi friends!
I hope you can help me.
I want to test PowerPac 3D printing, but I have robotstudio 6.08 and a Windows 7 PC. Will PowerPac 3D printing work with robotstudio 6.08 on a Windows 7 computer? Thanks for the answer.
  • Hi,
    No, 3D Printing PowerPac requires RobotStudio 2019.5.
    ABB Robotics
  • OK, thanks!
    Can I change the orientation of the tool separately for each layer differently? Or Orient the tool at a 45-degree angle toward the center ( for a square model).
    Unfortunately, I didn't find a way to do this... Do you have any ideas? Thanks.
  • With 'Constant Orientation' you can not change the tool orientation between the layers. The orientation will be fixed during the complete print. With 'Aligned Orientation' the tool will rotate around the Z-axis so the X or Y axis is aligned with the path direction.
    ABB Robotics
