Problems to startup a working station (some controller dont connect)
Hi, I'm new here in that forum
First some information about my used system:
Software:
Robotstudio:     2019.5.4 (64-Bit) Version 7.0.8746.0631
Painting Powerpac 2019.3          Version: 6.10.0034.0069
Hardware:
Workstation Dell Precision          Corei9
Memory:            32 GB
Graphic:             NVIDEA Quadro P5200
Display:              4k
My Problem is:
Nearly every time, if I open a station, some controllers don’t connect it stops at starting.
If I first open an other station, which brings the same problem, then I can start that station which I want to use without any problem.
As well I’m not able to close RobotStudio with that station, which have the problem, there I have to go to the task manager and kill RobotStudio.
Did any one have this problem and have a solution to solve, I think, that there are starting some processes before it have to…
kind regards
 Ralph
