PC SDK API documentation website is down?
When I search for “IpcQueue.Send” in Google, the first two results are from developercenter.robotstudio.com and the excerpt of the search result contains API documentation for IpcQueue.Send method. However, if I click into the search result, it will redirect to the homepage of https://developercenter.robotstudio.com/ and as a result I was not able to read the actual API documentation. Is this a known problem and is there a way around it? Thanks!
Best Answer
