Robot studio Stimulation
I have done a stimulation using robot studio,it is working fine ,and then I have transferred to real controller,then I have set the axis values same for both virtual robot and real robot using the same tool data ,still visually there is a difference between both robot.
Can, anyone explain how this error will occurs?
  • DenisFR
    DenisFR ✭✭✭
    Is your robot well calibrated?
    Move your robot to [0,0,0,0,0,0] abs position to check it.
  • yes I have done a mistake in calibration, and now it is solved.
    thank you denisFr for your guidance.
