Pick Master 3 Serial Communication Issue With Industrial PC
Hello All,
I am currently testing 2 NEW IRB-360's with IRC5 controllers, w/
- Pickmaster3 Installed On iPC, functioning correctly.
- AB CompaqLogix PLC working perfectly with both IRC5 Controllers and conveyors.
- Schneider HMIGTU panel
- Option Ethernet/IP 841-1 Installed.
- iPC is a B&R 910 iPC with 2 Configurable RJ-45 Ports (1 Used for Robots 1,2) DB-9 Port available for RS-232 i RJ-45 Port available. .
My situation: How can I control pickMaster3( Open Project, Close ,Start, Stop... ?
I have read the PM3 User manual section on RIS and selected option TCP/IP
The program has been configured and default values are used for all project and robot commands.
Does anyone have a sample of the code required to provide this functionality. I have tried tech support but they don't have any information to provide.
Thanks In Advance
Thanks In Advance
Hi, if you look in the pickmaster manual there is a chapter regarding RIS2 API, for example:
Starts a project.
Returns project status message.
HTTP MethodPUT
Parametersprojectpath: the path to the project to start.
Usage example:Request URL:
"http://somehtmladdress.com/pickmaster/startproject/ ?projectpath=C:\PMProjects\Project1.pmproj"
Response:
<?xml version="1.0" encoding="utf-16"?>
<ProjectStatusMessage>
<ProjectPath>C:\PMProjects\Project1.pmproj</
ProjectPath>
<Status>1</Status>
</ProjectStatusMessage>
