Calibration
How do one calibrate the robots? I've read the manuals but don't get it anyway. I'm running MultiMove with two IRB140 robots.
You can calibrate just one of two robots in a flexpendant you must go to the ABB menu then click in CALIBRATION and it will apear your two robots, select the robot that you want calibrate ROB_1 for example.
I don't kown if hi response to your question!
regards,
Joao Fidalgo
