The system service port that RobotStudio emulates is always changing, not the 80 in the documentatio
What do I need to set the service port number to be fixed at 80?
  • According to the prompts in the video, I added listenSecure-1 in AppWeb. conf, which led to the failure of startup of the simulation robot. After note, it can start normally
  • dnilsson
    dnilsson
    edited June 2020
    You are at the right place, you should modify appweb.conf. But you have mixed things up a bit.
    Listen -1 ==> Is for HTTP connection. Defaults to 80 if you don't have any server running on localhost port 80 that interfere then it will assign a random port. If so the specify the port manually by exchanging -1 to the port number you wish to use instead.
    ListenSecure 666 ==> Is used for HTTPS which normally uses port 443 not port 80. Using -1 here will result in a random port assignment so specify the port you wish to use here (not port 80).
    TL;DR
    For HTTP:
    Change "Listen -1" to "Listen 6767" to have the VC always listen on port 6767.
    For HTTPS:
    Change "ListenSecure -1" to "ListenSecure 6767" to have the VC always listen on port 6767.
    Post edited by Maxim Riabichev on
