Safemove 1.1
Using RS 2020.... where did the documentation for Safemove 1.1 go? Online documents doesn't work, takes me to "my dashboard" ,...which has nothing to do with online documentation...
Mike Kegley
Yes, from the dashboard you need to use the search function in the top right corner. Try search to search fr "Safemove manual" and you should be able to find it.0
