System builder can’t show default systems
In system builder of RS508 we can't show default systems if we choose right folder.
It's strange cause that can show only systems other than default systems.
We want to copy or modify default systems.
Can anyone give us advise?
BR
Yu
  • Hi,
    There are no default systems installed with RS 5.08. Instead there are "Template Systems". When you select a Template System, a new system will be created, and this system can you use as the old default systems.
    ABB Robotics
  • Hi Anders,
    Thank you for your reply.
    I can understand.
    Yu
