Wrong mediapool
Hello, I have RS5.07 on one computer and have just installed 5.08 on another. I am trying to transfer one of my real stations across to the newer system but am getting the following error.
What can i do? or what am i doing wrong?
"Argon Technology - your industrial robotics and automation partner, helping you build your tomorrow"
The problem is that you don't have RobotWare 5.07.0153 installed on your computer.
So you could do one of the following things
- Install RW 5.07.0153
- Edit "program.id" in the "INTERNAL" folder of the system to reflect the correct path to the MediaPool
- Use the System Builder to create a new system from the backup(from the other computer) and use that instead.
Consat Engineering
